2011 Sonata Limited 2.0t Headlamp Replacement
Old 08-31-2011 | 10:16 AM
sizz's Avatar
Default 2011 Sonata Limited 2.0t Headlamp Replacement
I purchased Hoen H8 "Endurance" (Yellow) bulbs to replace the OEM White Fog Lamps. Have installed but not had a chance to evaluate them yet. I now have purchased Philips "Vision Plus" H7 bulbs to replace the OEM Low Beam headlights.
Has anyone replaced their low beams? I noticed that the OEM bulbs are held by some type of "clip". Is this what locks the bulb in place? I do not want to removed the original lamp without knowing what I'm doing. Any help is appreciated.
Old 08-31-2011 | 10:50 AM
Yes, that is correct.
The info/pics in the following threads might help:
https://www.hyundaiforum.com/forum/h...eam-bulb-8843/
https://www.hyundaiforum.com/forum/h...lacement-9805/
Old 08-31-2011 | 02:49 PM
sizz's Avatar
Default Low Beam Replacement
Thanks. The passenger side was a little tricky as they had the "clip" intertwined with the two wires on the female socket. Took a little doing. Driver's side went with no problems. Thanks........
daveagre
08-28-2013 08:23 PM
jharrer1980
03-15-2012 02:43 PM
Spacheen
05-04-2010 06:18 PM
Maliki
04-24-2010 05:32 PM
Quick Reply: 2011 Sonata Limited 2.0t Headlamp Replacement
