2011 Sonata Smart Key battery replacement
Old 08-20-2011 | 02:59 PM
rajp53's Avatar
Talking 2011 Sonata Smart Key battery replacement
Can anyone provide instructions as to how to open the smart key unit for battery replacement? The car is an '11 Sonata. I found the slots on each side. Is there a secret? Are there instructions? Many thanks!
Old 08-20-2011 | 05:08 PM
Why do you need to replace the battery? The car is only a year old? Have you read your owners manual?
Old 08-20-2011 | 07:06 PM
rajp53's Avatar
Default 2011 Sonata Smart Key battery replacement
Hello Nova:
Yes I have read the manual. I'd like to know how to replace the battery for when it does in fact, require replacement.
Thanks.
Old 08-20-2011 | 08:29 PM
pete c's Avatar
Both fobs for my '09 Sonata still going strong at 3 years old. How long should I expect the batteries to last?
Old 08-21-2011 | 08:22 PM
Really? You read the manual? Did you miss page 4-11?
The fobs for my 2006 Tucson and 2006 Sedona are 5 years old and still working.
Attached Thumbnails 2011 Sonata Smart Key battery replacement-2011-sonata-4-11.jpg
Old 08-22-2011 | 10:30 AM
rajp53's Avatar
Hello Nova:
Yes I did see that entry, but I still cannot open it. Thanks for the time and attention.
Regards
Old 08-22-2011 | 10:36 AM
The instructions seem clear to me but if you are still having problems, I'd suggest going to the dealership and having a mechanic take care of that for you.
Best Regards
Old 10-18-2012 | 01:17 PM
ackc618's Avatar
Use the right size screw head (similar to the slot size) and it will pop open when you twist the screw driver. I tried a smaller head (.250") and it didn't work. I used the one that's .375" wide. So, if I were you, I will try
to find a flat-head that's at least .350" wide. Good luck!
smlindeman
04-08-2014 08:58 PM
btpena
03-26-2012 12:23 AM
gointotheralph
07-07-2011 08:49 AM
kland
06-09-2011 12:20 PM
Fantine
09-23-2010 06:09 PM
Quick Reply: 2011 Sonata Smart Key battery replacement
