3 Questions about '02 Sonata
Hello all,
This entails 3 different questions:
1. I have this loud squeak coming from the rear passenger side shock/tire area. If i bounce the corner up and down its super load... but when driving and I go over 50mph, I can't hear it anymore. What is it? Is the strut bad? Maybe the rubber mount for the spring? I can't figure it out.
2. I have anther squeak in the center dash area... almost sounds like a Relay flicking back and forth super quick... but everything in the dash and instrument panel is working fine.... thoughts?
3. This may relate to question 1 as well... I bought the car back in November, it has aftermarket rims and tires, and whenever I hit a large bump or dip in the road the back tires scrape on the wheel well. The distance from the tire to the wheel well is the same in the front as the back... but when I put anything in the trunk, even 2 cases of pop... I can run over a small crack in the road and it will scrape.
The Rims are 17" and the tire size is P235/50 R17 the front tire has a bubble and all 4 have about 1/4" of thread so I want to buy new tires soon.
Thanks for all the help!
Hello all,
Hello all,
