30,000 Mile Check up?
Old 01-07-2009 | 05:36 PM
joannerista's Avatar
Default 30,000 Mile Check up?
I have an 07 Sonata GLS, it's got 33k miles on it. All the 30,000 mile check up "packages" from the dealer and others are extremely expensive almost $400. Is there more important things to do at the 30k check for less money?[&:]
Old 01-07-2009 | 05:46 PM
jsinton's Avatar
Banned
Default RE: 30,000 Mile Check up?
The big thing is the trans flush, if you have automatic. Consult your owners manual.
Old 01-07-2009 | 07:18 PM
If you want to keep your factory warranty, you need to get the service done. If you don't and you have a problem later, Hyundai will void your warranty because you failed to do the required maintenance.
At 30K you need an oil change (with filter) and automatic trans fluid flusk, a coolant flush, new air filter, new cabin air filter, tires rotated, and numerous inspections.
Maintainance is part of owing a car.
Old 01-14-2009 | 09:59 PM
boilerman's Avatar
$400 a $20 trans filter and what 12 quarts tranny fluid(if they completely flush the system)$48 rotate tires $7.50/tire $28 oil change with filter and gasket $28 non-hepa cabin filter $40 coolant 1 gallon $25 $240 in parts/ fluids maybe $275 plus labor $100 sounds about right
JayI10
04-18-2020 12:46 AM
cyper2002
12-03-2007 11:38 PM
mitt
03-10-2007 08:01 PM
05SonataNew2Me
02-12-2007 03:18 PM
noni
10-03-2006 03:15 PM
