99 Sonata horn location (not working)
My 1999 Horn is not working. So Its either the switch on the wheel (I hope not) or a bad cable harness or horn. I can check the horn but can not find it. Can some one tell me where they hid it? You can allways toot it and see...I can't [:@]
Thanks!
Thanks!
RE: 99 Sonata horn location (not working)
Ok I found at least two 10 Amp fuses that were bad. I will have to check the rest tomorrow and get them replaced. I will post back to see what gets fixed lol. BTW I do not have any fuse cover to tell me what fuse is what....
Maybe this will help.
Condenser / 20A
Pwr Window / 30A
Ign Switch 1 / 30A
ABS 1 / 30A
ABS 2/ 30A
Ign Switch 2 / 30A
Radiator / 30A
1 / Rear Defog / 30A
2 / Not used
3 / ECM / 10A
4 / Passenger Comp Junction Block 1 / 30A
5 / Tail Lamp / 20A
6 / Sunroof / 15A
7 / Power Amp / 20A
8/ Passenger Comp Junction Block2 / 30A
9 / Blower / 30A
10 / Not used
11 / Front Fog Lamp / 15A
12 / DRL / 15A
13 / Not used
14 / Head Lamp High / 15A
15 / Head Lamp Low / 10A
16 / EGR / 15A
17 / Oxygen sensor / 15A
18 / Ign Coil / 20A
19 / Main (Engine Control Relay) / 30A
20 / Horn / 20A
21 / A/C Compressor/ 10A
22 Injectors / 10A
23 ABS / 10A
24 / Auto Trans / 15A
25 / Fuel Pump / 20A
Condenser / 20A
Pwr Window / 30A
Ign Switch 1 / 30A
ABS 1 / 30A
ABS 2/ 30A
Ign Switch 2 / 30A
Radiator / 30A
2 / Not used
3 / ECM / 10A
5 / Tail Lamp / 20A
6 / Sunroof / 15A
7 / Power Amp / 20A
9 / Blower / 30A
10 / Not used
12 / DRL / 15A
13 / Not used
16 / EGR / 15A
18 / Ign Coil / 20A
20 / Horn / 20A
22 Injectors / 10A
23 ABS / 10A
OK Fuses replaced wires connected to horn but when I push on the horn it feels VERY empty and like there is no horn contact. Can anyone with a 99 verify this feeling when they push the horn button down? Its weird its like there is no airbag (and I do have an airbag light on). I asked the tech at the dealer and he said if the air bag deployed then the wheel would be toast. My wheel :looks" fine just feels empty.
ORIGINAL: Doohickie
Condenser / 20A
Pwr Window / 30A
Ign Switch 1 / 30A
ABS 1 / 30A
ABS 2/ 30A
Ign Switch 2 / 30A
Radiator / 30A
2 / Not used
3 / ECM / 10A
5 / Tail Lamp / 20A
6 / Sunroof / 15A
7 / Power Amp / 20A
9 / Blower / 30A
10 / Not used
12 / DRL / 15A
13 / Not used
16 / EGR / 15A
18 / Ign Coil / 20A
20 / Horn / 20A
22 Injectors / 10A
23 ABS / 10A
Condenser / 20A
Pwr Window / 30A
Ign Switch 1 / 30A
ABS 1 / 30A
ABS 2/ 30A
Ign Switch 2 / 30A
Radiator / 30A
2 / Not used
3 / ECM / 10A
5 / Tail Lamp / 20A
6 / Sunroof / 15A
7 / Power Amp / 20A
9 / Blower / 30A
10 / Not used
12 / DRL / 15A
13 / Not used
16 / EGR / 15A
18 / Ign Coil / 20A
20 / Horn / 20A
22 Injectors / 10A
23 ABS / 10A
WheelBroker1[sm=americanasmiley.gif]
Thanks Doohickie!
Since I can not locate a manual your help is very useful for me.
Three questions:
1. Can you tell me where the horn relay is?
2. Can you email me the file you attached I could not view and assume its the graphics show what numbers are associated to which fuse physically. My fuse box has no numbers.
3. Again asking my airbag light is on not sure if its related to the horn problem. BUT it feels empty when I push in to sound the horn. I know this sounds stupid but I am wonder if ther is even any contact under the pad. Is this the "relay" you are refering to? Is this part of the airbag assembly?
Three questions:
