ABS/ESC warning lamps
Old 05-18-2008 | 03:11 PM
kevkat2's Avatar
Default ABS/ESC warning lamps
FYI: The ABS/ESC warning lampslit up on my 06 Sonata. Also, the brake lights would not come on. Took it to the dealer expecting $$$$. Turned out to be the brake switch. Fixed under warranty in about 10 minutes. Why it istied together, who knows? But I post this in case you have a similar situation.
Old 05-18-2008 | 04:18 PM
ken99's Avatar
Default RE: ABS/ESC warning lamps
Why it is tied together, who knows?
Because all the components you listed (ABS, ESC, the brake light switch) as well as the Traction Control System are all integral to the brake system on the car. Iinternal diagnostics on the brake system determined the switch was malfunctioning, which tripped an error code that lit up the ABS and ESC lights on the dash.
Old 05-19-2008 | 10:33 AM
Double J's Avatar
Question - does my 2007 Sonata have a function that alerts me when the brake pads are getting low and need to be replaced before the rotors get affected? I've heard of some cars having this, but I'm not sure if this car does.
Old 05-19-2008 | 11:55 AM
Actually, yes it does. But it's not an electronic monitor that illuminates a light in the dash. Each brake pad has a small piece of metal that will come in contact with the rotor when the pads are low. The metal tab will cause a squealing sound when driving (not while braking). If you hear that squealing, it's time to check your pads.
Also, as the pads wear, less brake fluid returns to the master cylinder. So when the master cylinder is low on fluid, it's a good indication that the pads are worn. DO NOT ADD FLUID! Check the pads first and replace any worn pads. If you add fluid first and then try to replace the pads, you will have to remove fluid form the master cylinder. The braking system is designed to remain closed. The ONLY reasons to add brake fluid is if there is a leak or if you are totally replacing the fluid. There is no need to bleed the brakes when changing pads unless the system is leaking fluid or air has gotten in the system.
Old 05-19-2008 | 09:03 PM
kevkat2's Avatar
I agree with you that the ABS, ESC are integral to the brake system. But come on, the cheap *** brake light switch? That is what I meant. And I have to wonder how many people have paid big $$$ for repairs when all that is wrong is a cheap switch? It reminds me of the old Aerostar van I once owned. The horn stopped working. Needed to get it inspected. Can't pass inspection without a horn. Went to the Ford dealer. Bad airbag sensor. Cost several hundred to repair. How is the horn and airbag system tied together? They are not. Just a crappy way to design a car.
Old 05-19-2008 | 10:28 PM
ken99's Avatar
You asked a question and I tried to answer it without getting too specific. So you think the brake light switch has nothing to do with your car's ABS system? The attachment is the basic wiring schematic of the ABS system to your Sonata. In the upper right hand quadrant you will find the 15A "STOP" fuse listed. Below that is the "Stop Lamp Switch". If you trace the wiring down from the switch, it branches at a joint connector providing a feed to the stop lamps at the back of the car, and a feed to the ABS module. Hmmm. Wonder how the ABS initially knows that you've applied pressure to the brake pedal? Yes, the brake light switch feeds current to a logic circuit in the ABS module that activates the ABS to start monitoring the wheel sensors before you've depressed the pedal far enough to build significant line pressure to the brakes. A similar connection exists between the switch and the ESC, since it needs to know if you are applying brakes as it compensates. Also that little brake light switch is wired to the cruise control system, signaling it to disconnect when you apply the brake. The brake light switch also controls the lock out solanoid that engages when you place the automatic transmission in Park. Since it is wired to and controls so many systems in the car, I would say "yes", the brake light switch is integral to the systems it is connected to and involved with.
[IMG]local://upfiles/4972/FE371C06B59C4CF685914857A32C5E38.jpg[/IMG]
Old 05-25-2008 | 12:34 AM
kevkat2's Avatar
To Ken99,
I never said the "cheap *** brake switch" had nothing to do with the ABS, Einstein. But being you are a "SuperMember" complete with cape and tights, I will bow to your arrogance, and your way too detailed knowledge.Nowshut the #%&^ up.
Old 05-25-2008 | 08:13 PM
ORIGINAL: kevkat2
To Ken99,
Maybe you missed this:
https://www.hyundaiforum.com/rules.asp
[quote]
Hyundai Forum - Rules
Hyundai Forum membership is diverse, covering people from various countries, backgrounds, ages and experiences. Considering this diversity and to make Hyundai Forum enjoyable for the majority of our membership, we have adopted the following simple posting guidelines.
1. Vulgar language, images and other offensive material including, but not limited to, race, nudity or pornography is not tolerated here. The Hyundai Forum staff shall be the sole judges of what does and what does not violate the boards standards.[/align]
2. While debating and discussion is fine, respect your fellow enthusiasts. Being of a diverse background, members are likely to express different opinions, and while opinions may differ from yours, they are just that, opinions; and everyone is entitled to express theirs freely. We will not tolerate rudeness, insulting posts, or personal attacks. Do not flame, bother, bug, disrespect, hound or taunt ANYONE on the forums or through private messaging or chat room. If we feel a thread is getting out of hand we will close or delete it. You can/will lose your posting privileges if you continue this type of behavior.[/align]
3. "Trolls or Trolling", "Flames" and/or "Board Wars" are not tolerated here or elsewhere. Posts that taunt or are otherwise inflammatory against other sites will be removed. Also, anyone found to be making inflammatory posts and remarks on other forums (starting Flame/Board Wars) can and will loose their posting privileges here. This rule also applies to those that, for whatever reason, feel a need to post negative remarks about this site on other forums. If you do, don't expect to be welcome here.[/align]
4. Double posting is not allowed and can result in the deletion of one or both posts. Double posting is defined as posting the same information in two or more separate forums. We understand that some topics might fit into more than one forum. Please try to pick the best one. In addition, please do not post in the same thread back to back (another version of double posting), if you have something more to add, edit your post, don't post twice in a row in a thread.[/align]
5. Selling or solicitation of ANYTHING in the general forum, by Private Message or in Chat is considered Spam and is not allowed. Anyone found posting excessive links to their websites, or suspected of "sneaky" advertising will be warned and will possibly lose their posting privileges. Please post your private party ads in the Hyundai Forum Classifieds forum sections. If you are a business and have a product or service that would be of interest to our members, visit our Advertising/Sponsorship page to learn how you can join our team and help support our community. We offer a variety of low-cost packages that can be of great benefit to your company.[/align]
6. [font=verdana]Please refrain from posting meaningless threads, one word (or short), "smiley" only, non-sense posts and such. Multiple or repeated posting in order to increase your post count ("post whoring") is frowned upon. If you do engage in this type of activ
Old 06-28-2008 | 11:51 PM
itsthebigb19's Avatar
Actually it is recomended every 2 years that you flush the old brake fluid out because it can carry alot of water, remember brake fluid gets hot, gets moisture in it and brakes down. If I got my brakes done I would hope they would bleed it a little.
ORIGINAL: NovaResource
Old 06-29-2008 | 03:29 PM
ORIGINAL: itsthebigb19
Getting the brakes hot has nothing to do with moisture getting in. Moisture gets in when you open the system or there is a leak. Yes, changing the fluid every few year is recommended but there is no reason to open the system and bleed the brakes when just replacing the pads.
