Brake noise
Brake noise
Hi
I have a 2002 Hyundai Sonata that has a high pitched squeal when every the brake pedel is depressed. I had the brakes checked out by a mechanic and they said they are very good. I have no problem stopping but attention and head turning from others regarding the squeal is frustrating-any ideas what this may be?
I think I would find another mechanic. They should be able to figure out what it is. If you explained what the issue is and they drove it and experienced it themselves but still say the brakes are fine then you shouldn't be trusting them to work on your car. Brake noises can be difficult to diagnose over the internet but a competent mechanic should not have any problem figuring it out when they have the car there in front of them. It's safe to say that the noise you describe is not normal.
i have a very similar problem, the issue with mine is the fact that the rotor is about 1 inch smaller all the way around so only have the brake pad is being used, i will see if i can get some pictures up, just sharing what my problem was you may wanna check and make sure this isnt the same problem you are having
tocrazie
10-16-2014 02:49 PM
Kalun47
07-26-2011 11:00 AM
