car dies on roadside then restarts
we have a 2001 sonata 4 cyl automatic, what could be causing the engine to die then after letting it sit for 10 minutes it restarts and goes another 3 miles and does it again.?
RE: car dies on roadside then restarts
Go to your local Autozone, and they will do an ODB II scan and tell you what the CHECK ENGINE light means for free, no charge. Then come back and tell us what codes you get.
ORIGINAL: jsinton
[align=left][/align]
I checked the codes and it can up crank shaft sensor.
Hi,
I had exactly the same problem on my 2002 Sonata and eventually found it wasa coil pack shorting out when the engine warmed up, so if youv'e replaced the crankshaft sensor and the problem persists I would suggest you check this out.
Chris
Chris
The part is not that expensive, and probably easy to put in:
http://www.autozone.com/Action,partT...eResultSet.htm
I don't know where it goes, but you can find out at the offical website:
hmaservice.com
hmaservice.com
PhoebeAnn
02-16-2012 10:01 AM
serialxt
08-22-2010 10:48 PM
rokuez
05-12-2008 04:56 PM
