car rolls/falls off jack
Old 04-03-2007 | 04:01 AM
ErbeyJ's Avatar
Default car rolls/falls off jack
I know this is the incident we all try to avoid, but i guess it happens ....
what happens to the wheel? rotors? or axle? when the car falls/rolls off the jack stand and on to the ground (with no tire on)
does it cause seriousdamage?
will it make either of the above bent, twisted, or out of align?
Old 04-03-2007 | 04:17 PM
dah005's Avatar
Default RE: car rolls/falls off jack
i suppose you have already done this , well any way,hear goes first make sure you can get the tire on straight if not do not!!!! put it on you can damage the wheel barrings if you can get the tire on straight find a flat road it should be at least 1quarter mile excelerate slowly and take your hands off the stirring wheel see if car is pulling to either side if so you need an alignment also listen for grinding sound when excelerating and braking if you here this you my need brake work could be something as simple as having your brakes adjusted, keep us informed of your results.......;tl
fencer66
03-21-2012 08:24 PM
Fastmover
05-31-2011 11:46 PM
ra42mario
05-07-2008 08:45 PM
tehutton
06-12-2007 12:39 AM
LeVeque
12-11-2006 11:47 AM
