Console shifter light
Old 04-04-2010 | 08:45 AM
mcdonaldt's Avatar
Question Console shifter light
The year on the car is 2004 and the light(LED?) under the console to the left of the shifter(P,R,N,D) is burned out or a loose wire. How do you access the bulb?
Old 04-04-2010 | 07:33 PM
Remove console panels enough to access bulb-socket -
1.Pry the rear upper cover from the floor console with a flat-tip screwdriver.
2.Remove the front upper cover from the floor console after removing 2 screws.
3.Remove the floor console mounting screws (2EA) and bolts (2EA).
4.Remove the floor console assembly after removing 4 screws.
5.Installation is the reverse of removal.
Lmar1
02-02-2019 02:57 PM
riebe
09-26-2012 04:14 PM
Lmar1
12-07-2011 09:55 PM
coupeladlee
01-29-2011 07:04 AM
zappyisfun
12-04-2009 11:17 PM
Quick Reply: Console shifter light
