Engine starts then stops after 2 or 3 seconds
Old 05-12-2010 | 11:18 PM
scottdcole's Avatar
Default Engine starts then stops after 2 or 3 seconds
I just finished swapping out my flywheel, clutch assembly, and manual transmission. The car started and ran great for about 15 minutes. Then, when coming back from store, when starting the car again, it would start just fine for 2-3 seconds then just "shut-down". It would repeat this cycle again and again.
I also noticed my "check engine" light was on. I still have not hooked back up my oil sending unit, my reverse gear module, or my speedometer unit (Ineed to get a new one first.)
Should my car start and stay running with these still disconnected? Is there something else under the hood I might have inadvertantly unhooked, or some wire or unit I might have damaged? I'm baffled and hope someone can tell me how the t-shoot this problem.
Old 05-18-2010 | 11:04 PM
Island Guy's Avatar
Check engine light means it stored a trouble code so go to a big parts store like Advance Auto, have them pull the coeds for free and they'll give you a print out of what caused the check engine light. Could be staving for fuel, when was the last time the fuel filter was changed? Is the fuel pump pressure within proper parameters? Failing fuel pump could make the engine start then stop. Get the codes pulled then go from there.
dave763
02-07-2014 01:07 PM
danicacar
06-11-2010 09:30 AM
dbiker1
05-03-2010 08:43 PM
02sonata
03-25-2010 03:13 AM
CaptAthlon
12-20-2009 09:44 AM
