hard starting sonata
Old 11-28-2005 | 09:36 PM
cmkerns's Avatar
Default hard starting sonata
my 2000 sonata has been trouble free until it turned 100K miles. It has since started hard starting. You have to crank it 2-3 times for it to start and it stumbles a little when it starts. Tune up at 70K when belt replaced. Any ideas?
Old 12-01-2005 | 01:12 AM
mnstrmech's Avatar
Default RE: hard starting sonata
1 i would start by checking the fuel pressure regulator, simlpy unplug the vacuum line from the regulator, then turn on the key to prime the car, if fuel comes out the hole, then its bad, needs replacing.
2 if thats good, then check out the plugs, what kind of plugs are in there?
3 fuel pressure would be another good place to check, except that you need a special adaptor to check pressure.
most of the time, a hard start follewed by a stumble, but runs fine is usually a leaking fuel pressure regulator.
Old 12-19-2005 | 02:05 AM
cmkerns's Avatar
The fuel pressure regulator was replaced (along with the fuel filter) and it starts perfectly again
Thanks
rosie
08-26-2020 04:33 PM
psykoconnell
11-16-2011 12:23 AM
dwcollins2
05-13-2010 03:35 AM
jimbonewbie
01-06-2009 09:00 PM
phoenixsun
06-12-2007 02:01 PM
