How do I get access behind ashtray of 2009 Sonanta?
Old 07-13-2010 | 03:18 AM
anon44's Avatar
Default How do I get access behind ashtray of 2009 Sonanta?
The front cover of the ashtray (the place where the lighter receptacle is) was up and I dropped something on top of the cover that slid down behind the ashtray.
How do I get behind to retrieve the lost object?
It looks easy to reach if I could figure out how to remove the plastic sides of the center console. But I don't see any screws and I don't want to lift up the plastic too hard and break it.
By the way, when I bought the car I used decovin.expert
Thanks for any help.
Old 07-13-2010 | 06:43 AM
Floor Console Replacement
• When prying with a flat-up screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage.
• Put on gloves to protect your hands.
1. Remove the **** (A).
2.Remove the console under cover (B).
3.Disconnect the connector (C).
4.After loosening the mounting screw, then remove the center fascia lower panel (A).
5.Disconnect the connector (A).
6.After loosening the mounting screw, then remove the upper center tray bezel (A).
7.Remove the crash pad center fascia panel (A).
8.Disconnect the connector (A).
9.Disconnect the heater unit connector (B).
10.Gently detach the hook, remove the parking brake cover (A).
11.After loosening the console mounting screws, then remove the floor console assembly (E).
12.Disconnect the connector (B).
13.Remove the console side cover (A).
14.After loosening the mounting screws, then remove the front console (A).
15.Installation is the reverse of removal.
biffstr
01-09-2021 10:41 AM
DJHONG
04-07-2014 09:38 AM
MetalX
08-10-2012 03:17 PM
ericpeck1
07-15-2012 02:01 PM
Bonnie Mazza
07-28-2010 08:20 AM
Quick Reply: How do I get access behind ashtray of 2009 Sonanta?
