Howling engine
Old 05-04-2005 | 08:26 PM
amirio's Avatar
Default Howling engine
Im driving a 2004 Sonata (gold)
After 1 year of comfort driving the 4 cylinder , 16 valve enging
starts to give a funny sound.
The engine gives out a "howling" sound.
It happens only after the car is parked for about 2 to 3 hours
and when you start the engine and drove with a speed of about 25 kph
with 1st and 2nd gear.
Kindly advise
Thanks
Old 06-07-2005 | 11:39 PM
hyundai tech's Avatar
Default RE: Howling engine
Listen for the noise from the timing belt area. Those vehicles were bad about the timing belts coming apart.
Old 02-01-2006 | 02:37 PM
Chris B Williams's Avatar
If your noise is only occurring when you are on the move, it could be a worn brake pad, as these have sensors in them which give off a high pitched squeel, instead of having a warning light on the dash.
Old 02-03-2006 | 11:08 AM
hyundai_sonata_gle's Avatar
i've had the same issues with my 95 sonata it is the belt tentioning arm that needs replacing good luck
mrsifter
01-15-2015 09:51 AM
CAW
06-12-2012 04:54 PM
billmach
02-12-2008 06:26 PM
