Sonata 2011 door speaker replacement
Front or rear door?
Front Door Trim Replacement
• Be careful not to scratch the door trim and other parts.
• Put on gloves to protect your hands.
1.Using a screwdriver or remover, remove the quadrant inner cover (A).
2.Remove the inside handle cover (A).
3.After loosening the mounting screws, then remove the front door trim (A).
4.Remove the inside handle cage (A).
5.Disconnect the connectors (A), and then removing the front door trim.
6.Installation is the reverse of removal.
Rear Door Trim Replacement
1.Remove the delta inner cover (A).
3.After loosening the mounting screws, then remove the rear door trim (A).
4.Disconnect the inside handle cage (A).
5.Disconnect the connectors (A).
Front Speaker
1.Remove the front door trim panel.
2.Remove the front speaker (A) after loosening 4 screws.
Rear Speaker
1.Remove the rear door trim panel.
2.Remove the rear speaker (A) after removing 4 screws.
Front Speaker
Rear Speaker
I have a 2011 with six speaker system plus sub woofer
WO navigation With Sub Woofer.
Very disapointed by the sound system and was also thinking about replacing the door speakers, how did this work out for you.
I ended up replacing the speakers from Crutchfield, bought the boston acoustics for around 120 a pair, great improvment.
Rear door speakers have full sound so use a two way, front door speakers are base only so you need to replace tweeter in dashboard also, new tweeters in the dash realy help. All stock speakers are labeled 2 ohm impedance? nobody makes that. the four ohm speakers still have pleanty of volume. this is actually less strain on the amp.
I replaced all my speakers and installed an alpine hx 650 signal processor and an alpine amp. Sound is much improved. This was the only system I could fine that allowed me to keep the factory head and steering wheel button functionality.
I mounted tweeters on the front door sails and disconnected the dash mids.
Rut
Rut
removing sail
I am cautious removing the sail and afraid of breaking it, do these parts just pry up or do you move towards one dirrection? these are the first plastic parts to remove the door trim on either front or back door. Thanks
Yes. The sails just pop straight out. They are held on pretty tightly so it does require some effort. I actually had to cut out one of the mounting tabs on the sail to get my tweeters mounted as they required a hole for mounting. The remaining tab still holds it on tightly though.
Best of luck
Rut
Best of luck
Rut
