speed sensor change
Old 01-01-2009 | 02:45 PM
kendar's Avatar
Default speed sensor change
sonata 1998. The speedmeter doesn't work and want to know how to replace the speed sensor's behind the cluster. Or am I wrong?
How many speed sensor are there in this car?
Thanks
Old 01-01-2009 | 03:59 PM
ken99's Avatar
Default RE: speed sensor change
sonata 1998. The speedmeter doesn't work and want to know how to replace the speed sensor's behind the cluster. Or am I wrong? How many speed sensor are there in this car?
There is only one speed sensor on the 98 Sonata, mounted on top of the transaxle. The picture is from a 2002 Accent, but it gives you an idea of what the 3-pin sensor should look like on the Sonata transaxle.
Here are the diagnostics for the 1998 Sonata sensor with a multimeter (from http://www.hmaservice.com/).
VEHICLE SPEED SENSOR[/align]
1. Disconnect the speed sensor connect and remove the speed sensor.[/align]
2. Connect the positive(+) lead from battery to terminal 2 and the negative(-) lead to terminal 3.[/align]
3. Connect the positive(+) lead from tester to terminal 1 and negative(-) lead to terminal 3.[/align]
4. Turn the speed meter shaft using a flat driver.[/align]
5. Check if there is voltage change from about 0V to 11 V or more between terminal 1 and 3.[/align]
6. The voltage change should be 4 times per each revolution of the shaft.[/align]
Old 01-04-2009 | 12:53 AM
ken99's Avatar
If I change the speed sensor allready, but, the speedmeter still doesn't work, what the problem can be?
Either a problem with the wiring harness, a problem with the gear drive below the sensor, or a bad speedometer head unit. On these type of systems, it tends to be the later.
ejc2180
04-23-2021 02:55 PM
itskeiser
01-16-2021 12:39 PM
CptnNemo
01-02-2013 10:49 PM
seiken
02-18-2008 10:00 PM
Sonatatrouble
05-23-2007 09:32 AM
