When changing sparkplugs V6 2000 sonata
Old 04-06-2008 | 12:45 PM
justinity's Avatar
Default When changing sparkplugs V6 2000 sonata
What has to be done when changing the plugs on a v6 2000 sonata? I thank I have to take the intake manifold off any help would be great here is a pic of it it would be great if i can get to the back 3 plugs without takin it off but I think its unavoidable
Old 04-06-2008 | 01:04 PM
ken99's Avatar
Default RE: When changing sparkplugs V6 2000 sonata
Here is a link to the procedure on a 01 Santa Fe with the same engine (2.7 liter Delta V6):
http://members.aol.com/dwjatwwk/santafe.html
Has a very good set of pictures set up in step-by-step order. Should help you with your task.
Old 04-07-2008 | 08:10 AM
I don't own a Sonata but the 2.5L V6 in the Sonata is basically that same engine as the 2.7L V6 in the 2003-up Tib (with some minor differences to fit the different chassis. Below are 2 links on how to do iton the Tib. It should be the same for the Sonata.
This one explains how to remove both the upper and lower manifolds (you only need to do the upper half):
http://www.newtiburon.com/forums/showthread.php?t=1760
http://www.newtiburon.com/forums/showthread.php?t=70634
GWFL
02-26-2008 09:34 AM
kthall
11-10-2007 07:44 PM
Sparkplugs.com
01-22-2007 09:42 PM
Patrick
Off Topic
12-01-2006 02:24 PM
Brant
07-11-2006 01:32 PM
