where's my oil filter on 2000 V6?
Old 11-05-2005 | 02:54 PM
genedancemachine's Avatar
Default where's my oil filter on 2000 V6?
I thought I'd try changing my own oil for the first time. But I cannot find the oil filter. I'm guessing it must be a difficult one to replace if it is this hard to even locate. The owners manual does not say where it is located or illustrate the location. Any help would be appreciated - thanks in advance.
Old 11-11-2005 | 05:25 PM
jeff49's Avatar
Default RE: where's my oil filter on 2000 V6?
You can't see the oil filter from on top. Locate the dip stick, follow it and note where it disappears. The oil filter is sorta below there. If you look in that general area from the underside, you can see it easily. Changing it is fairly easy as you can get to it easily from the underside. There is enough room there that I can usually loosen mine by hand.
Jeff
Old 11-17-2005 | 06:48 PM
Thanks for your response. I found it underneath. However, on my Sonata the oil filter was covered by a metal piece held by two screws. It appears to be a protective covering of some sort. That's why I could not find it before.
Now if I could just get the drain plug unstuck. Looks like I'm gonna end up at Jiffy lube afterall *sigh*
Old 02-26-2008 | 08:30 PM
james_75's Avatar
Hi genedancemachine, the best way for you to know where's your oil filter located, try to go to automotive shop this will help you.
Old 02-27-2008 | 08:52 AM
Hey james_75, I believe genedancemachine found the filter 2 years and 3 months ago. At least, I'm assuming that based on the post he made on 11/17/05. But thanks for the help.
Aggie_1990
01-17-2012 01:28 PM
mrmr256
12-08-2011 10:54 PM
valleydavid
10-29-2007 01:07 PM
derek slang
05-18-2007 07:59 PM
ShortBuSX
12-09-2005 11:21 PM
