Hyundai Terracan The Terracan offers mid-sized sport utility space in the body of a compact SUV.
diff lock for the Terracan
Old 01-16-2005 | 04:40 PM
pwven's Avatar
Default diff lock for the Terracan
Din Cane</P>
Am interested on feedback from the diff locker. Have you installed it and what is your finding?</P>
Piet Venter</P>
  #12
Old 01-20-2005 | 07:29 AM
Din Cane's Avatar
<SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Verdana">As a matter of fact NO.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o></SPAN></P>
<SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Verdana">Still have a problem with an automatic locker....<o></o></SPAN></P>
<SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Verdana">Really prefer to have a manually controlled one.<o></o></SPAN></P>
<SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Verdana">Did you ever drive an automatic one?<o></o></SPAN></P>
<SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Verdana">Din<o></o></SPAN></P>
</P>
  #13
Old 01-23-2005 | 03:25 PM
pwven's Avatar
Hi Din</P>
No did not drive na auto locker and do not have any xperience with auto lockers. I also prefer a manual one.</P>
What is the details of the auto locker supplyer so that I can contact them from my side?</P>
Piet</P>
  #14
Old 01-26-2005 | 02:16 PM
Dane's Avatar
Default RE: diff lock for the Terracan
Din,
I am looking to install a rear and perhaps a front ARB Air Locker on my Terracan. But I can't get the prices from ARB until I know the technical details about the diffs. I thought they were borrowed form the Pajero, but according to Hyundai, that is not the case.
They can't tell me the exact details, and I have been adviced to let a mechanic (the car is still under warranty) take apart the diffs to get the details. But this is expensive.
Do you have the details of the diffs? The Pajero is as follows, but is not identical to the Terracan:
&gt;RD110 - Front Air Locker.
&gt;RD25 - Rear Air Locker for disc brake models.
&gt;
&gt;
&gt;The specifications for differentials are as follows:
&gt;
&gt;Specifications: RD110
&gt;
&gt;* 28 spline axle
&gt;
&gt;* 28.8mm [1.10"] axle shaft diameter (outside of splines)
&gt;
&gt;* 10 bolt ring gear
&gt;
&gt;* 124mm [4.88"] dia. ring gear ID
&gt;
&gt;* 45.3mm [1.78"] ID tapered roller bearings
&gt;
&gt;* 32mm [1.26"] axle stub bushing dia.
&gt;
&gt;Specifications: RD25
&gt;
&gt;Axle Spline 28 tooth, Ø30.5mm [1.20"]
&gt;
&gt;Ratio Supported All
&gt;
&gt;Ring Gear ID 145.0mm [5.71"]
&gt;
&gt;Ring Gear Bolts 12 bolts on Ø175mm [6.89"]
&gt;
&gt;Ring Gear Torque 85Nm [63 ft-lb]
&gt;
&gt;Backlash 0.13-0.18mm [0.005-0.007"]
&gt;
&gt;Bearing Cap Torque 60Nm [44 ft-lb]
&gt;
&gt;
Dane
  #15
Old 03-20-2005 | 11:25 AM
Din Cane's Avatar
Dane,
the Pjero and the Terracan are not the same.
the axle is completely different.
we took it a part and you cant use an ARB Pajero locker on it.
if you have some more news ill be happy to know.
take care
din
  #16
Old 03-30-2005 | 05:02 AM
Dane's Avatar
It was ARB's best guess that the diff was the same as Pajero, seeing that the Galloper was Pajero based. But I spoke with Hyundai, and they told me it was a completely different diff, but they were unable to give me the information ARB needed to determine which ARB diff is required. A bit disappointing. Hyundai's advice was to get an authorized ARB dealer to take the diff apart to determine what diff is needed. But I live en Denmark, and there is only one ARB dealer here, and it's a long way away from where I live. Plus I first have to drive there to get the diff taken apart, then have it put together again and drive over there again when the ARB diff arrives. Plus I have to pay for the work as I have no idea how to assemble a diff once taken apart.
That's why I am looking for someone who has already taken the diff apart and retrieved the information that ARB needs to send the right diff. But there are not a lot of Terracan owners who have tried this I guess?
Din, do you know if the diff/rear axle of the Terracan is 100% Hyundai made or is it adopted from somewhere?
  #17
Old 05-04-2005 | 03:26 AM
Din Cane's Avatar
I found a diff locker for the rear.
Its automatic one.
The diff is completely different from all other diff; i can only guess that Hyundai developed it on their own.
after we will finish with the installation of the rear one i will post my comments.
  #18
Old 05-26-2005 | 09:06 AM
Dane's Avatar
Looking forward to hearing about it
Where did you find it?
  #19
Old 05-28-2005 | 08:14 AM
pwven's Avatar
Din Cane
Yes please us feedback on the diff locker. I am sure there are other's intersted in it.
Pwven
  #20
Old 06-03-2005 | 12:52 PM
Din Cane's Avatar
as we found out, the locker was planned for a non LSD diff, as my car does have the LSD.
the locker is here and i placed an order with the local Hyundai dealer for non LSD gear diff, i should have it next week
as soon as its installed i'll let you know.
since i do real offroad its should be great
