01 tiburon front wheel bearing
Old 12-14-2008 | 12:23 PM
bigbri3137's Avatar
Default 01 tiburon front wheel bearing
i have a 2001 tiburon. i think my L/F wheel bearing is bad again.it's very costly so i'm going to try it my self.i have the break down of it. when reading the notes there are a lot of special tools listed,are they all needed,or can you just use a hyd. press to get the hub apart and then press the bearing out also do you have to press the hub from the knuckle or will it come out with ease? the notes also say when removeing wheel hub or wheel bearing from knuckle replace wheel bearing assembly (outer race, inner race,and grease seals). i can only find the wheel bearing none of the other parts. is it possilbe the other parts are for new cars or different models. are there any bearing or seals that go on the hub it self. it seems to me after you press new bearing in the back side of the knuckle and replace the snapring .will you need to press the hud threw the knuckle into the bearing or will it just slide in? the wheel bearing it self is a sealed bearing so it should not need any grease (right)? is grease needed any where else. and if anyone could help with torque setting that would be great. at last how hard of a job is this. hope someone can help! thank you!
Old 12-14-2008 | 02:55 PM
Default RE: 01 tiburon front wheel bearing
https://www.hyundaiforum.com/m_15838/tm.htm
256barry
10-07-2011 09:45 AM
Rdturbulence
07-27-2011 10:47 PM
jaycman
10-27-2009 11:32 PM
derekio
07-30-2009 09:44 AM
lijo929
10-13-2008 02:40 PM
Quick Reply: 01 tiburon front wheel bearing
