03 gt clutch question
Me And my girlfriend just purchased a white 2003 gt 2.7 v6 from a car lot and they say they just put a new clutch and flywheel in it then i came home and got online and they say there are problems with the clutches on the 2003 model.. am i still going to have problems with it and if so what will cause the problem... thanx guys
RE: 03 gt clutch question
If the work on your Tiburon was performed by a Hyundai dealership, the repair is likely good. If not, you may wish to ask who did the repair work and find out exactly what they did. If they replaced the flywheel with a solid one along with a new disk and pressure plate, it's probably OK and will be quite servicable for many years (depending how you drive, of course). The worse case scenario? That somebody simply replaced the disk and/or the pressure plate without regard to the flywheel situation. It's easy to find reports on the Internet about early clutch failures in Hyundais where mismatched components were used.
speeder
03-09-2008 07:05 PM
mjnor1
10-08-2007 02:34 PM
