2003 tiburon
2003 tiburon
Help! rear bulb is out and I can't remove the right rear lense to change it out. I've removed 5 nuts from behind and the lens is a bit loose, but will not disengage from the body to access the bulb. What am I missing? Nothing in the owner's manual regarding lens removal. Thanks in advance.
RE: 2003 tiburon
A Taillight bulb? Once you removed all the bolts you need to gently but firmly Hit the tail light housing facing the rear of the car hitting towards the rear end. Its hard to explain. How to do it is in my owners manual but I have a 2006
krm5@earthlink.net
12-08-2005 03:06 PM
