2006 SE Starting issues
Now i know there are alot of threads already about this....BUT everyone else seems to be at least getting a clicking sound when turning the key.
My issue is this...I have a 2006 Tiburon SE with about 60,000 miles. The problem only happens very randomly, when you go to turn the key to start the car it does absolutely nothing...no clicking or anything....sometimes if you try again and again it will fire up...sometimes you have to just not do anything then try and your good.
Keep in mind when you turn the key ALL of the electronics work i.e. Radio, windows, lights, etc...
So i know the battery and everything is fine....all i can think of is that the start is just starting to wear out and go bad...any input would be great!
I had this exact problem -- I actually made a thread about it. I thought it was due to extreme cold weather (like -35 overnight kinda thing) but it turns out it was due to a loose grounding connection on the battery. My battery was fine and the electronics would work (90% of the time) but when I depressed the clutch and turned the key, nothing would happen. No light, radio, clicking. It was like the car didn't have a battery at all.
Hope that helps.
Hope that helps.
