99 tiburon no fire no fuel pls help sitting with no car for 6 months now
i have a 99 tiburon fx. the tenth vin is f. i recently have replaced the blown motor with a used one. i have no fire no fuel. i have scanned the car but no codes come up everytime. i have replaced the crank position sensor, cam position sensor, and the ecu, but nothing has worked. i have checked the continuity for the wires leading to the crank position sensor from the ecu and it is good, the ecu has ground. what is wrong? also when we first tried starting the car after replacing everything the drivers door started to smoke.. evidently the drivers door lock shorted out.. wud that cause the security system to keep it from starting? even if no codes are still showing? wud that cause the 5 volt signal not to be relayed to the crank position sensor? please if anyone can help you would be a life saver....
sincerly matthias
sincerly matthias
HyundaiCarProblem
03-21-2009 06:21 PM
