ac compresspor belt
Old 08-08-2009 | 05:52 PM
cdwr's Avatar
Default ac compresspor belt
how do you remove the ac compressor belt on a 2001 tiburon
Old 08-08-2009 | 06:52 PM
I believe you have to remove the alternator belt first .
1. Loosen the belt tension on the alternator.
2.Disconnect the magnetic clutch connector.
3. Lift up the vehicle.
4.Loosen the locking nut of the tensioner.
5.Sufficiently lessen the tension of the compressor drive belt by turning the tension adjusting bolt counterclockwise.
6.Lower the vehicle.
7.Derail the compressor drive belt from the compressor pulley.
Robin Hood
03-14-2022 03:24 AM
mevin69
11-06-2011 04:14 AM
mdevlin
02-04-2011 10:36 AM
Rhondas
11-01-2008 03:48 PM
Rhondas
10-15-2008 08:09 PM
