airbag removal?
Old 11-26-2008 | 12:42 PM
stehlar24's Avatar
Default airbag removal?
Is there a sticky on removal of the steering wheel? Steering wheel switch is bad for the horn. Airbag light has been on for a while now. I ran a hard wire from the battery terminal to the horn itself. Scared the carp outta myself. I know thats not the problem. Also installed a new Horn relay. I know thats not it either. Last thing has gotta be the steering wheel switch. Mayeb a spring or something. If anyone has any ideas or reccomends anything. Please let me know.
Thanks alot guys,
Mike
Old 11-26-2008 | 04:06 PM
jsinton's Avatar
Banned
Default RE: airbag removal?
Since the horn and the airbag are faulty, I would suspect you are having a problem with power to the steering wheel assembly. 2000 Sonatas had a recall for wiring harness for airbags.
Old 11-26-2008 | 11:00 PM
stehlar24's Avatar
Im to the point where I'll just remove the steering wheel and install an after market one. Frustrating. I don't wanna get raped by the dealer either.
Old 11-27-2008 | 07:41 AM
jsinton's Avatar
Banned
Disconnect your battery for 30 minutes and turn the key on before you start messing with the steering wheel. It is possible to accidentally set off the airbag and kill yourself.
zainecurtis
04-05-2013 02:34 AM
poseidon010
01-13-2007 08:32 PM
Rossmore
08-21-2006 07:43 PM
wim crone
03-11-2006 09:27 AM
Swampy
02-17-2006 06:17 PM
Quick Reply: airbag removal?
