Burning smell from driver's side front wheel
Old 12-15-2010 | 02:18 PM
sccericola's Avatar
Default Burning smell from driver's side front wheel
I have a 2006 Tiburon SE (manual; 6-speed). I have been noticing a burnt smell from the front drivers side wheel after parking in my garage. Yesterday I noticed what appeared to be an oil-like (dark) substance where the same wheel was sitting while parked overnight in the garage. Any ideas? The oil-like substance was only by the one wheel and none of the others had this.
Old 12-15-2010 | 03:27 PM
Check the caliper to see if it is stuck. Also, check the CV joints.
Old 12-18-2010 | 02:08 PM
sccericola's Avatar
Everything is fine I guess. Went to my mechanic and he couldn't find any problems. My timing belt is due for replacement (60000 miles) soon as well as new spark plugs, belts, hoses etc. I was also informed that it is wise to replace water pump etc. when they change the belts etc. Is this true? Grand total that I was quoted for everything is 1000 dollars (includes tune-up parts and labor as well as belts, water pump. spark plugs. Does this sound reasonable or should I get another opinion?
caitlinW
01-26-2012 09:01 AM
Nocturnal
10-07-2011 05:06 PM
tib01
04-15-2009 04:07 PM
accentblack
02-04-2009 08:17 PM
accentblack
01-09-2009 08:39 AM
