Clutch help
Clutch help
Yer i have a 96 hyundai coupe/tiburon and the clutch is gettin on my nerves. It releases the clutch point at the very end of pressing the pedal, like i mean really at the end, how would i change this so that it releases at a lower point
thanks
thanks
RE: Clutch help
na it doesnt grab at high revs or anything its just the friction point needs to be adjust like the clutch is all good anything its just that its friction point releases at a high point like not half way just near the end blahhh its annoyin
RE: Clutch help
i had an s10 that needed its clutch bleed and it was doing similar things to what you are saying,,,or if its like in my tibby when i bought it,,,the clutch was half way ingaged due to the clutch fork being rusted and seized. your problem could be as simple as a clutch adjustment, or you may just need to change it, depending on the miles and how you drive,,its probably a good thing to do anyway.
speeder
03-09-2008 07:05 PM
mjnor1
10-08-2007 02:34 PM
