Clutch Problem
Old 04-12-2006, 06:26 PM
jakeb157's Avatar
Default Clutch Problem
Hello
I recently replaced my clutch and now i only have like a 3" swing to my clutch pedal. i havent tryed to start it or move it as of now. Ive had the transmission out about 4 times trying to find out whats wrong and everything seems to be ok. if anyone has experienced this before please help me.
Old 04-14-2006, 07:31 PM
flave1's Avatar
Default RE: Clutch Problem
has anyone tried adjusting the clutch pedal buddy im sure there is a rod near the pedal which is adjustable.
Old 04-18-2006, 06:15 PM
jakeb157's Avatar
no there is nothing on the pedal that is adjustable b/c i thought the same thing.
Old 04-19-2006, 07:03 PM
flave1's Avatar
in that case have you tried bleeding the system?
Old 04-20-2006, 05:59 PM
jakeb157's Avatar
yup completely cleaned the system, new fluid and bleed the system.
Old 04-23-2006, 04:12 PM
flave1's Avatar
ok so can you engage any gears without stalling or any crunching?
Old 04-24-2006, 05:36 PM
jakeb157's Avatar
at that time no i couldnt. but i found out why i had the short swing was b/c the slave cyl. was bottoming out. but it still wasnt disengaging al lthe way. no i needed the car to drive home b/c my college year ended so i mod. the release lever so it did disengage but im going to have to find out why it didnt want to disengage before.
Old 04-24-2006, 05:44 PM
flave1's Avatar
this might sound daft but have you got the correct clutch kit installed because if you can move the slave to the end of its stroke then it must be a mechanical fault like either the wrong release bearing or pressure plate?
Old 04-24-2006, 08:46 PM
jakeb157's Avatar
yeah we thought the same thing but we measured both sets and they are within .001 of each other. not enough to make a difference.
Old 04-27-2006, 07:02 PM
flave1's Avatar
is it the pull type clutch as in the 1.8/2.0/2.7 or is it the push type in the 1.6?
Quick Reply: Clutch Problem
