Dash lights and right tail lights not working!! help!
#12
BCM stands for Body Control Module. It is possible the dash lights and the tail lights are related, but I would try to change the tail light bulb first. Switch the left one with the right one just to test.
If the tail light bulb is just burnt out, then all the better.
Next, who did the faceplate on the radio? Was it a commercial shop? If so, I would take it back to them. It might be a loose wire, but if they shorted the BCM and burnt it, then they are responsible. You are supposed to remove the negative battery cable off the battery before you start to work on the electronics on a modern car, just so you don't burn the electronics like that.
So a few questions for you to answer.
#13
More info here: https://www.hyundaiforum.com/forum/s...ead.php?t=5836
However, it sounds like the car has multiple electrical "issues":
Bad alarm: https://www.hyundaiforum.com/forum/s...ead.php?t=5265
Bad Horn: https://www.hyundaiforum.com/forum/s...ead.php?t=5587
My daughter has a 03 Tiburon. She purchased a radio faceplate to replace the Infinity one that was not showing digital channels. It was installed by a friend of hers. After it was done some of the dash lights and lights for the console do not work. Also her right rear light is out. Anything I can look at? Fuses?
#14
Its not the bulb and I told my daughter to have a qualified installer do it but you know kids they do not listen. Well this most likely will cost her more money than a qualified installer would have done it correctly the first time.
Thanks for the info
Thanks for the info
#15
i had the same problem when i installed my in dash player.. after 2 warnings and a repair order i searched everywhere on the internet.. the culprit turned out to be the tail-rh fuse .. once i replaced the 10 fuse everything lit back up and works fine.... now on to the dc sport ceramic headers
