Engine Swap
Old 01-14-2006 | 05:59 PM
MakingYellowSnow's Avatar
Default Engine Swap
I have a 1997 Hyundia Tiburon. The engine has gone through alot of abuse (not changin oil, letting run hot for too long, etc.) by the previous owner. The Tiburon is not an FX so I was curious if you could swap out the old 1.8L and put in the FX 2.0L. If so what modification would be needed to do so?
Old 01-18-2006 | 12:08 AM
whiterice's Avatar
Default RE: Engine Swap
you dont need anything to do the swap. however i would stay with the 1.8 transmission (it is a manual right?). the 1.8 trans is geared lower for more acceleration. also use the 1.8 headers and stock cat. much better flow. ecu's are interchangable. the 1.8 intake cam is also better in the 2.0 if you can do that while its out.
good luck
Old 06-22-2006 | 07:35 PM
titusrogers's Avatar
Does the info on the 1.8L - 2.0L also apply to the elantra?
Old 07-20-2006 | 06:51 PM
flave1's Avatar
YES
skip donohue
02-25-2012 09:31 PM
aaloe1017
08-04-2010 09:00 AM
damonmlime
03-29-2007 07:29 PM
riverking
03-03-2006 04:27 PM
SkiddyK
07-02-2005 06:07 PM
