high rpm at 60mph
Than that is normal. The 4-cyl engine 5-speed manual has a 5th gear ratio of 0.837 and a final drive ratio of 4.056. With the 215/45-17 tires (24.6" diameter) the engine RPM at 60-mph would be 2800-rpm.
70-mph would be 3250-rpm
80-mph would be 3700-rpm
That's just it, it's not a small car. The GK Tiburon weighs just about 3000-lbs. Your old Corolla was about 2400-lbs. That's a 600 pound difference. That's Physics 101. Put three 200-lbs guys in that Corolla with you and see if it gets the same mileage as it does with just you in it.
mpryjd2
02-27-2007 04:00 PM
