How to Remove Stock Radio in 2003 Tiburon
Old 12-02-2008 | 06:00 PM
Harry454's Avatar
Default How to Remove Stock Radio in 2003 Tiburon
Hey can anyone tell me how to remove the stock radio in 2003 tiburon gt without infinity system, or post a link to a guide thanks
Old 12-02-2008 | 06:27 PM
Default RE: How to Remove Stock Radio in 2003 Tiburon
It's very simple, Just open the ashtray then put your fingers under the center bezel where the ashtray is and pull it out. Once the center bezel if out, just remove 4 screws and the head unit slides out. Very simple.
https://www.hyundaiforum.com/m_9819/tm.htm
https://www.hyundaiforum.com/m_10712/tm.htm
Old 12-02-2008 | 07:00 PM
Harry454's Avatar
and regards to wiring I bought the wiring Harness, so I would just connect the wires from deck to harness then connect harness to stock harness correct? also I got a indash dvd deck so like would I need to install the Ebake switch detector, if I dont then the unit will play movies while driving right instead of only when parked.
Old 12-03-2008 | 08:18 AM
Yes, that's the best way to connect an aftermarket head unit. That way you don't chop up the factory harness.
Old 12-03-2008 | 09:28 AM
Harry454's Avatar
regards to ebrake how would i go about connecting it? Is the wire already in the harness
Old 12-03-2008 | 09:34 AM
No, it's not. You'll have to tap the wire in the console where the e-brake handle is.
Old 12-03-2008 | 11:30 AM
Harry454's Avatar
how would I go about accessing the ebrake console and where exactly do i connect the wire? Any link to a guide or some? Thanks a lot
Old 12-03-2008 | 12:24 PM
The wire for the parking brake switch is attached to the parking brake lever.
To access the switch you need to remove the console:
CONSOLE REMOVAL AND INSTALLATION
1. Remove the front seat.
2. Remove the console upper cover.
3. Remove the console front mounting screws.
4. Remove the floor console.
5. Installation is the reverse of removal.
DDs99Tiburon
01-18-2009 12:19 AM
Mangole
12-31-2008 06:42 AM
mikibark
01-15-2007 11:41 AM
AriesXX
01-05-2007 10:45 PM
AriesXX
05-02-2005 11:16 PM
