Mod questions for 04 Tibby
Sup ALL
Finally joined the Tibby family and had a few question. Can someone recommend some sites or after markets parts for my 04 Tibby V-6 (Exhaust, Cool intake, supensions, etc). I also want to replace the infinity stereo and speakers and wanted to know if someone could give me a hint on taking out the stock stereo? I want to replace the current instrument decals and need information on taking the odemeter apart to replace the stock decals? Thanks in advance and glad to join the Tibby community!
Thanks
X
Thanks
X
RE: Mod questions for 04 Tibby
hey X a good site to check out for your tib is www.sharkracing.com
also to remove your stock radio the whole panel around it is removed ( it just pulls right off) and then remove all of your electrical plugs
remove the 4 philips head screws and the radio slides right out (approx 10 mins worth of work). with the gauge cluster i can't help you with that cuz if never had to removed yet. hope this info is of some use...
to take off the guage cluster you remove the 2 philips head screws holding the cover on and just pull straight out..then undo the 4 screws around the cluster and pull it out and unplug the connectors
