Tiberon headlamp out
One of my daughter's 2003 Tiberon headlamps doesn't work. She's under the impression that the entire assembly needs to be replaced. Isn't there a way to just replace the burned out bulb(s)? Thank you.
It's TubUron, and yes, you can replace just the bulb. Just be sure to avoid touching the bulb itself. The oil from your skin will create hot spots on it and cause it to burn out quicker.
HEAD LAMP/TURN SIGNAL LAMP
1.Disconnect the negative battery terminal.
2.Remove the front bumper upper cover.
3.Remove the head lamp and turn signal lamp mounting bolts (3EA) and remove the lamp assembly.
4.Installation is the reverse of removal.
