2005 Tucson Tires, want bigger oner any suggestions
Old 01-17-2011 | 05:40 PM
4shanon's Avatar
Default 2005 Tucson Tires, want bigger oner any suggestions
Hi,
I would like to get taller and wider tires on my 2005 tucson. right now it looks all wimpy with 215/65R15... Can anyone with knowledge of tires suggest what size i should go for. i dont need to go extreme it just doesnt look right. Thank You!
Old 01-17-2011 | 06:23 PM
You don't want taller tires because it will throw off the speedometer and odometer. Also, too tall will cause interference. If you want a slightly wider tire you can go with the tire size that is standard on V6 Tucsons: 235/60-16
Old 01-18-2011 | 03:09 PM
4shanon's Avatar
Default what about...
I found some 265/60 -16 for a real good price. would those work? I know I sound stupid but Im just some gal who wants better looking tires. I never had to worry before, never had ones that looked so akward
Old 01-18-2011 | 05:11 PM
The 265/60-16 tires is over 1.5" taller and 2" wider. Way to wide and too tall. And I highly doubt the tire woudl fit on the 6.5" wide factor wheel. It's just too wide.
Old 01-18-2011 | 06:34 PM
4shanon's Avatar
Thank you Super Moderator! I'll keep looking...
Old 02-01-2020 | 02:12 AM
Adam White's Avatar
235/65-16👌
they only rub a tiny bit when hard over either side
'06 Tucson limited V6 4WD USA
Vanga
12-23-2010 12:52 AM
T_rum
06-01-2010 08:40 PM
Veneetraj
03-26-2009 04:44 PM
ericnottelin
01-17-2009 05:25 PM
big mamoo
04-23-2008 02:36 PM
