2005 tucson wheel stud
Old 11-24-2008 | 08:13 AM
algrimm1964's Avatar
Default 2005 tucson wheel stud
How do I replace the wheel stud on a 2005 tucson. Can it be done without removing the rotor/hub assambly?
Old 11-24-2008 | 10:18 AM
Rdturbulence's Avatar
Default RE: 2005 tucson wheel stud
i have never seen the hub of a tuscon, but you should be able to get it out without removing the hub. if its broken off, get an impact with a punch bit and you should be able to get right out, it may take a little time, but it will go, you could also try getting it started with a hammer, but be careful not to hit the hub or to hit it too hard to where you could bend a mount or something, its not likely but it could happen. let me know if you need help with anything else, take a picture of it if you are still having problems. good luck
albert520
09-19-2020 06:11 AM
kittybabe
03-12-2009 08:57 AM
marcsyl
09-21-2008 03:52 PM
bECS
04-10-2008 07:38 AM
devorguila
12-09-2005 12:24 PM
