2006 Tucson - bad smell only in Winter
Old 01-24-2011 | 09:24 PM
texaspete's Avatar
Default 2006 Tucson - bad smell only in Winter
Hi,
We have a 2006 Tucson Limited (V6). Ever since we got it we've noticed a chemical-ish hot type smell that only happens in the winter. I'll pull the car in the garage and come out a bit later and the whole garage smells. I've asked the dealer a few times and they said they don't notice it and can't find anything.
Does anyone else have this problem?
Thanks
Old 01-25-2011 | 09:41 AM
Hard to say without actually smelling what you smell. Can you describe the odor more?
Old 02-06-2011 | 07:03 PM
texaspete's Avatar
To me, it's a chemical smell. Do these cars do something different in the winter time than the summer time?
Old 02-06-2011 | 07:15 PM
austex04's Avatar
How long have you had it? The only thing I could think of would be your a/c evaporator is dirty, or you have a slow coolant leak somewhere. What part of Texas you in? Do they use ice removal chemicals where you live during the winter, if the roads get bad?
Old 02-07-2011 | 07:56 AM
texaspete's Avatar
We've had it since new, January 2006. I'm from Pennsylvania (Texas Pete is a hot sauce I like).
We've noticed the smell since we got it. At first I thought it was something burning off the engine since it was new. The 2nd year I became suspicious and have told my dealer every winter check up since and they can't find anything.
Old 03-05-2011 | 07:41 PM
Cajunsim's Avatar
Default cab filter?
I have a new 2011 that had a glycol/antifreeze odor. They went in behind glove box and sprayed something to clean vent/filter. It cleared it up. May give it a shot-good luck.
Old 04-07-2011 | 09:25 PM
Cajunsim's Avatar
Default Was only a temp fix
The smell has returned. It reminds me of antifreeze and I wonder if there is any vent/overflow/etc that would allow air to circulate over some part of engine that vents or contains antifreeze. Just a thought and have no clue where to start looking to figure it out. Will mention again on next service to dealer.
Old 04-07-2011 | 10:25 PM
austex04's Avatar
Are you noticeing very small amounts of coolant disappearing from the recovery bottle? Have them check the heater core hoses, and the heater core itself, it could have a tiny leak. If it does, it would be evident if they opened up the core case.
Old 06-01-2011 | 12:56 AM
YossiD's Avatar
Default Re: Bad smell
I've also been experiencing a smell for several months in my 9-month old i30cw. It comes and goes and sometimes I don't smell it but I do experience irritation in my throat and/or eyes. Would coolant have that effect?
It's a leased car, and the leasing company has checked several times but they didn't find anything. They changed the a/c filter a couple of times but that didn't do anything. Last time I think they sprayed the filter with fragrance or else put a deodorizer in the air duct because I now have deodorizer smell whenever I turn on the fan. I suppose if they can't find the source they figure masking it is a good alternative. Doesn't fix the throat/eye irritation though.
I will check the coolant recovery bottle and mark the level to see if it's changing.
shadango
10-27-2012 06:36 PM
vwatttx
03-19-2011 11:10 AM
karla
01-05-2009 10:59 AM
iancanada
12-05-2007 10:14 AM
Firebane
01-05-2007 07:44 PM
