2012 Tucson flooded, how to remove carpet?
Hi all, I'm trying to remove the carpet. The only part I cant take off is the shifter/arm-rest console. How do I remove the shifter/arm-rest console? Bolts inside the armrest compartment are already removed. Screws on each side already removed.
Console Assembly Replacement
• When prying with a flat-up screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage.
• Put on gloves to protect your hands.
1. Remove the **** (A).
2. Using a screwdriver, remove the floor console tray (A).
3. Using a screwdriver, remove the floor console bezel (A).
4. Disconnect the connectors (B).
5. Using a screwdriver, remove the console upper cover (A).
6. Disconnect the connector (B).
7. Remove the console tray mat (A).
8. Remove the extension side cover (A).
9. After loosening the mounting bolts and screws, then remove the floor console assembly (A).
