2016 tucson 1.6 limited
Code 2562 & 2563............visually checked all plugs and wires.....replaced boost sensor...same codes....now going after wastegate. NE1 have this isue before that might enlighten me. Thanks!
Before replacing anymore good parts, might be a good idea to verify the 5 volt reference voltage is getting to the sensor. If that checks out OK, then verify sensor has a good ground connection.
The codes point to an electrical problem in the boost pressure sensor system.
By the time you get done replacing a lot of good parts you might have better results having someone with the proper tools check this out.
