4wd lock does not work well
Hello,
I have some problems with my 4wd lock. Last weekend I was on a short brake with my family. Whe have a caravan (1.500 kg). The car was standing on wet grass so I locked de 4wd. There was no power and the wheels where spinning. The traction control was on. When I stopped pulling and unlocked de 4wd I felt a shock. Then everything was normal. I tried it again with the same results.
Does anyone knows whats wrong.
with friendly greetings.
Frank
The Netherlands
Frank
The Netherlands
Just because 4WD is locked doesn't mean you will move on a slippery surface. You were probably spinning all 4 wheels, that's why you didn't move. The shock you felt is probably because you didn't stop all 4 wheel before you unlocked the 4WD.
Hello again,
I tried the lock today again without the caravan. I noticed that when I turn the steering wheel compleet to the right or left the car will move difficult en the spinning starts. Just on the road. (not slippery). When I turn the steering wheel straight there is no problem. The tire profiles are ok.
Is the car using in lock state a low geering?
