brake push's back when braking??? HELP!!!!
Old 12-21-2008 | 05:51 AM
methodman1992's Avatar
Default brake push's back when braking??? HELP!!!!
my 05 tucson 4x4 is acting up!!!! it just started yesturday. when i hit the brakes i can feel the pedal pushing back and not that softly either!!! and there is a like clunk from the frontend! also when i hit the gas from a stop it kinda pulses now and then! not every time just every few stops! anyone know what the heck could be the problem?????????
Old 12-21-2008 | 02:18 PM
ken99's Avatar
Default RE: brake push's back when braking??? HELP!!!!
Have the roads become slick and/or icy lately? What you describe is the anti-lock brake system functioning as designed. If the system senses a wheel locking up into a skid, it will pulsate pressure to the slave cylinder to prevent the skid, which can be felt as you step on the brake pedal. If several wheels are involved, the back pressure could be substantial. Just keep a steady foot on the pedal as you apply brakes. Read page 2-11 of your owners manual.
Old 12-21-2008 | 03:07 PM
yes they have but it wasn't doing it befor i got on the highway! after driving about 2 hours i got off the highway and then it started! it also will surge on accel?/ is this the esp or wut?
Old 02-20-2009 | 12:30 PM
luleung's Avatar
Default same situation
omg, I thought I was the only one with this problem. But, my Hyundai Tucson 2006 4x4 has the same braking problem. This problem occurs when the roads are icy and slippery. Anti-lock brake pulsating pressure? My vechicle slides while the brakes pulses. I think it is absolutely dangerous! Any tips on how I should handle this when it happens again. I'm so scared to drive in icy conditions now because I can't rely on my Tucson 4x4. Help.
Old 02-20-2009 | 01:39 PM
^^^ That's normal. There is nothing wrong with your Tucson. That is the ABS releasing the brakes because the wheels have locked. If your Tucson didn't do that, the wheels would have stayed locked and you would have slid off the road and crashed.
The only thing you can do to prevent that from happening is to slow down when driving in icy condition (or buy studded tires). ABS can't change physics, it only prevents the wheels from locking. So if you brake too hard on ice and the wheels lock, ABS will release the brakes and reapply. Basically the ABS is telling you (through the brake pedal) to press lighter on the brakes.
Old 03-13-2011 | 10:57 AM
kljameswv's Avatar
My 95 v6 still has this problem even when the roads are clear and dry...is there any way of testing to see if the abs is malfunctioning?
Old 03-13-2011 | 10:59 AM
kljameswv's Avatar
sorry...I put 95 when i meant 2005 ....
rosie
08-26-2020 04:33 PM
vspinelli
03-01-2012 10:13 PM
UGAgirlyGirl74
03-01-2011 07:07 PM
schellmis
04-06-2007 01:23 AM
