Couple of questions
Couple of questions
My mom recently purchased a Tucsan...does the Tucsan have the same transmission issues as lets say the Elantra? Fluid specs?
And how exactly do you pronounce Tucsan? Like Tuc-san? Like Tuscan AZ?
And how do you describe this vehicle? Is it a truck? An SUV, a ut'? A sport crossover? What? I refer to it as a truck and she gets all offended...that its a car, based off the Elantra!
RE: Couple of questions
Sport Utility huh? So that would make it more "truck like" than "car like", right?
Are all Hyundais equipt with similar Mitsubishi automatic transmissions that require the special, dealer only, SP-III ATF??
Tuscon does not have any trans issues,come to think of it neither have elantras.Anyway, sp3 is only fluid to be used.Change it every 30k miles. Pronounce it like Tuscon AZ. It is a small SUV.Like a shrunk Sante Fe.
ORIGINAL: hyundai tech
Every 30k is another issue...I personally change my own ATF every 15k(its a Suzuki), the manual suggests every 70k, but with readily available fluids Im able to do it more often...and will have less issues with my transmission...not having to worry about the dealer hosing me with the wrong fluids(which Ive read several Hyundai dealers have a hard time using the correct fluids)...and Ive read dozens of reports of Elantra owners having fatal transmission problems.
Point is, this is a simple "oil change"...hardly worth the 70+ dollars the dealer charges...if the transmission internals werent so sesnsitive, a higher quality synthetic aftermarket fluid could be used...I really dont understand how this is not an "issue".
You can use alternate fluids, as long as their certified the same as what HMA goes by.
Also, everyone should use the 'Severe Conditions' column noted in the manual as far as servicing goes. Rest assured, if you have a warranty issue, it will be one less thing they can try and snake you on.
I used to take my 93' Corolla in every 50K for a Trani-Flush. Ran me around $100. The car now has over 230.000 miles on it, same transmission, no problems.
I'm a preventitave maintenance kinda guy. Take car of your vehicle, it will take care of you.
ORIGINAL: lbocean
scoby41
09-26-2006 04:19 AM
