ESC off ON
Old 03-12-2012 | 04:53 PM
elkarshofy's Avatar
Unhappy ESC off ON
I have a 2007 tucson 2.7 The ABS, ESC are ok but ESC off ON after i
Installed a new front CrossMember and filled brake fluid. What could this be?
Old 03-13-2012 | 12:38 PM
Can I have that in English please? I don't understand what you are asking.
Old 03-13-2012 | 04:57 PM
elkarshofy's Avatar
Thanks for replaying NovaResource. I have a 2007 Tucson. Last day I was filled my Tucson brake system fluid and the ECS OFF light came on. No matter how many times I pressed the ESC OFF switch, the light never flickered.
Old 03-13-2012 | 10:48 PM
First, why were you adding brake fluid? You should only add fluid if needed after changing brake pads. The fulid in the master will drop normally as teh brake pads wear. Never add fluid with worn pads.
Second, I don;t think the brake fluid has anything to do with the ESC. My giess is there is a problem with the ESC or the brake light switch. Does the cruise control work? Do the brake lights work? Has the brake light switch been changed as part of this recall: https://www.hyundaiforum.com/forum/g...e-lights-6251/
Old 03-15-2012 | 01:34 AM
elkarshofy's Avatar
I had a vehicle recall fixed on my car about three years ago and stop lamp switch was changed .
Old 03-15-2012 | 11:23 AM
Maybe the switch itself is bad. Did you check the fuses for the ESC? It's possible a wheel sensor or tone ring is bad. It needs to be checked out by a trained mechanic.
Old 03-19-2012 | 04:52 PM
elkarshofy's Avatar
Thank you so much , i have replaced stop lamp switch by myself and ESC light gone off
Dory
04-14-2021 03:29 PM
Skipperl
03-10-2013 01:16 PM
DrDemento
02-08-2013 07:43 AM
stanh
01-17-2012 08:33 AM
warren83
12-10-2010 04:40 PM
Quick Reply: ESC off ON
