Heated Seats
Tools. Mostly wrenches.
BTW, it's Tucson (like the city in Arizona), not Tuscan (like the region in Italy).
SEAT ASSEMBLY REPLACEMENT
1. Remove the seat assembly mounting cover.
2. After loosening the seat assembly mounting bolt and nut, remove the seat assembly.
3. Open the connector box (A).
4. Disconnect the connector (B), and remove the seat assembly.
5.Installation is the reverse of removal.
SEAT MOUNTING BOLT INSTALLATION PROCEDURE.
- Set the seat into the most rearward position. Check then each slide is locked, and then tighten the front mounting bolt temporarily.
- Set the seat into the most forward position. Check then each slide locked, and then tighten the rear mounting bolt completely.
- Set the seat into the most rearward position. Check the front mounting bolt completely.
- Check that the seat operates to and fro smoothly and the locking portion locks properly.
Eric.Walsh
05-22-2011 11:16 AM
Islandbound
12-31-2007 09:01 PM
