Homelink review mirror on 2011
Old 08-12-2010 | 09:56 PM
chester dog's Avatar
Default Homelink rearview mirror on 2011
Just bought a 2011 Tucson Limited on 8/8/10---love it! However, in going through the detailed owner's manual cover to cover checking out all the functions and features of my new ride, there is absolutely NO information on the features/opeartion of the rearview mirror with Homelink---just a standard rearview mirror. Sent an e-mail to Hyundai USA. Can anybody help with instructions in the meantime? And what's up with no 2011 brochures--even on line?! Hyundai Canada has theirs.
Old 08-12-2010 | 10:39 PM
www.homelink.com ---> it is their product, not a Hyundai produced thing, they just bought it from them to use in car as an added option.
The site will have links to various garage door makers sites, and I think you can select your vehicle and garage door opener to get direction on how to program the buttons
Old 08-12-2010 | 11:06 PM
Here's the directions for the Santa Fe manual. It should be the same:
Integrated HomeLink® Wireless Control System
The HomeLink® Wireless Control System provides a convenient way to replace up to three hand-held radio-frequency (RF) transmitters with a single built-in device. This innovative feature will learn the radio frequency codes of most current transmitters to operate devices such as gate operators, garage door openers, entry door locks, security systems, even home lighting. Both standard and rolling code-equipped transmitters can be programmed by following the outlined procedures. Additional HomeLink® information can be found at: www.homelink.com or by calling 1-800-355-3515.
CAUTION
Before programming HomeLink® to a garage door opener or gate operator, make sure that people and objects are out of the way of the device to prevent potential harm or damage. Do not use HomeLink® with any garage door opener that lacks the safety stop and reverse features required by U.S. federal safety standards (this includes any garage door opener model manufactured before April 1, 1982). A garage door that cannot detect an object - signaling the door to stop and reverse - does not meet current U.S. federal safety standards. Using a garage door opener without these features increases the risk of serious injury or death.
Retain the original transmitter of the RF device you are programming for use in other vehicles as well as for future HomeLink® programming. It is also suggested that upon the sale of the vehicle, the programmed HomeLink® buttons be erased for security purposes.
Programming HomeLink®
NOTICE
• When programming a garage door opener, it is advised to park the vehicle outside of the garage.
• It is recommended that a new battery be placed in the hand-held transmitter of the device being programmed to HomeLink® for quicker training and accurate transmission of the radiofrequency signal.
• Some vehicles may require the ignition switch to be turned to the second (or "accessories") position for programming and/or operation of HomeLink.
• In the event that there are still programming difficulties or questions after following the programming steps listed below, contact HomeLink® at: www.homelink.com or 1-800-355-3515.
Standard programming
To train most devices, follow these instructions:
1. For first-time programming, press and hold the two outside buttons, HomeLink® Channel 1 and Channel 3 Buttons, until the indicator light begins to flash (after 20 seconds). Release both buttons. Do not hold the buttons for longer than 30 seconds.
2. Position the end of your hand-held transmitter 1-3 inches (2-8 cm) away from the HomeLink® buttons while keeping the indicator light in view.
3. Simultaneously press and hold both the HomeLink® and hand-held transmitter button. DO NOT release the buttons until step 4 has been completed.
4. While continuing to hold the buttons the red Indicator Status LED will flash slowly and then rapidly after HomeLink® successfully trains to the frequency signal from the hand-held transmitter. Release both buttons.
5. Press and hold the just-trained HomeLink® button and observe the red Status Indicator LED. If the indicator light stays on constantly, programming is complete and your device should activate when the HomeLink® button is pressed and released.
6. To program the remaining two HomeLink® buttons, follow steps 2 through 5.
Rolling code programming
Rolling code devices which are "codeprotected" and manufactured after 1996 may be determined by the following:
• Reference the device owner's manual for verification.
• The handheld transmitter appears to program the HomeLink® Universal Transceiver but does not activate the device.
• Press and hold the trained HomeLink button. The device has the rolling code feature if the indicator light flashes rapidly and then turns solid after 2 seconds.
To train rolling code devices, follow these instructions:
1. At the garage door opener receiver (motor-head unit) in the garage, locate the "learn" or "smart" button. This can usually be found where the hanging antenna wire is attached to the motorhead unit. Exact location and color of the button may vary by garage door opener brand.
If there is difficulty locating the training button, reference the device owner's manual or please visit our Web site at www.homelink.com.
2. Firmly press and release the "learn" or "smart" button (which activates the "training light").
NOTICE
There are 30 seconds in which to initiate step3.
3. Return to the vehicle and firmly press, hold for two seconds and then release the desired HomeLink® button. Repeat the "press/hold/release" sequence a second time to complete the programming. (Some devices may require you to repeat this sequence a third time to complete the programming.)
4. Press and hold the just-trained HomeLink® button and observe the red Status Indicator LED. If the indicator light stays on constantly, programming is complete and your device should activate.
5. To program the remaining two HomeLink® buttons, follow either steps 1 through 4 above for other Rolling Code devices or steps 2 through 5 in Standard Programming for standard devices.
Gate operator & Canadian programming
During programming, your handheld transmitter may automatically stop transmitting. Continue to press the Integrated HomeLink® Wireless Control System button (note steps 2 through 4 in the Standard Programming portion of this document) while you press and re-press ("cycle") your handheld transmitter every two seconds until the frequency signal has been learned. The indicator light will flash slowly and then rapidly after several seconds upon successful training. Operating HomeLink® To operate, simply press and release the programmed HomeLink® button. Activation will now occur for the trained device (i.e. garage door opener, gate operator, security system, entry door lock, home/office lighting, etc.). For convenience, the hand-held transmitter of the device may also be used at any time.
Reprogramming a single HomeLink® button
To program a new device to a previously trained HomeLink® button, follow these steps:
1. Press and hold the desired HomeLink® button. Do NOT release until step 4 has been completed.
2. When the indicator light begins to flash slowly (after 20 seconds), position the handheld transmitter 1 to 3 inches away from the HomeLink® surface.
3. Press and hold the handheld transmitter button. The HomeLink® indicator light will flash, first slowly and then rapidly.
4. When the indicator light begins to flash rapidly, release both buttons.
5. Press and hold the just-trained HomeLink® button and observe the red Status Indicator LED. If the indicator light stays on constantly, programming is complete and your new device should activate.
Erasing HomeLink® buttons
Individual buttons cannot be erased. However, to erase all three programmed buttons:
1. Press and hold the two outer HomeLink® buttons until the indicator light begins to flash-after 20 seconds.
2. Release both buttons. Do not hold for longer than 30 seconds. The Integrated HomeLink® Wireless Control System is now in the training (learn) mode and can be programmed at any time following the appropriate steps in the Programming sections above.
FCC ID: NZLZTVHL3
IC: 4112A-ZTVHL3
This device complies with Part 15 of the FCC Rules.
Operation is subject to the following two conditions:
1. this device may not cause harmful interference, and
2. This device must accept any interference received, including interference that may cause undesired operation. NVS® is a registered trademark and ZNav ™ is a trademark of the Gentex Corporation, Zeeland, Michigan. HomeLink® is a registered trademark owned by Johnson Controls, Incorporated, Milwaukee, Wisconsin.
Old 08-14-2010 | 11:27 AM
THANKS! Will try this out today.
Old 11-20-2010 | 05:08 PM
USTNOTE50's Avatar
Just bought the same yr and model and discovered the Homelink wasn't mentioned once, except on the window sticker. The salesman never touched on it either.
Old 04-25-2013 | 02:48 PM
mommygoose107's Avatar
Default 2011 Tucson Homelink
Since trying to program Homelink (with no success) a red light keeps flashing on the dash facing forward. Any ideas why or how to stop it from flashing?
Old 05-01-2013 | 12:38 AM
osp6179's Avatar
If it's the red light on the dash up by the wipers, that is for the alarm system and not home link. The red light on the mirror will flash if there is an error with the garage door operation, but the two are separate.
I had to make three attempts before the programming took hold on mine. The biggest challenge is tripping the garage door "learning" mode and running through the steps before the timer runs out.
DrDemento
10-21-2012 03:27 PM
gettoboy
04-16-2012 01:57 PM
SantaFaer
11-04-2011 03:08 PM
mentomekelian
05-24-2011 10:56 PM
Mike99-123
07-05-2009 11:09 AM
Quick Reply: Homelink review mirror on 2011
