keyless remote replacement/programming
Old 12-30-2008 | 03:21 PM
judycarr's Avatar
Default keyless remote replacement/programming
I have a 2005 Tucson. I lost one of my keyless remote fobs and want to get a replacement. The dealer wants $140 seems like a lot of money. So I have looked online and have seen many offered for less. Problem: the ID numbers are not quite the same.
My unit is 95430-2E200, FCC OSLOKA-110T.
Online, all the keyless remotes I've seen for the Tucson are coded
95420-2E200, FCC OSLOKA-320T.
That last series of numbers concerns me. Are the two remotes interchangeable? Can they be programmed alike? At the worst, I could buy two of the 320T units and program them alike, providing it works with the car.
Also, does anyone have programming instructions for this remote? Or does anyone know where to locate them?
Thanks for your help Judy
Old 12-30-2008 | 04:51 PM
Default RE: keyless remote replacement/programming
You should have no problem. The OSLOKA-320T works fine on my 2006 Tucson.
However, you will need to go to the dealer to program them. It can only be done with a dealer scan tool. Be sure to take both remotes with you because you have to reprogram all remotes at the same time. Lastly, the Tucson only has the ability to remember 2 remotes. You can't program 3 or more.
pilyin
12-23-2009 09:58 PM
BuddyLee10
06-09-2009 12:29 PM
Rhanck
12-22-2008 10:06 AM
teachdqs
12-04-2008 11:30 PM
jaybarry1946
03-20-2007 01:38 PM
Quick Reply: keyless remote replacement/programming
