newbe 05 4x4 v6 Tucson with 200300 miles
Old 12-14-2010 | 08:27 PM
dr-death's Avatar
Default newbe 05 4x4 v6 Tucson with 200300 miles
Hello All
I just got a 2005 Tucson 4x4 v6 with 200300 miles
.. buts its new to me....
have paper work for New motor @ 182k
Rebuild transmission 186k
now i got it
Problems
under acceleration it has a vibration in one of the front wheels/axle
front end make noises like control arms have no bushings
check engine light "ON"
p0700
p0741
p0430
that is all the problems i have come across
are these common problems?
what is the Fix? any help ?
Old 12-16-2010 | 09:59 AM
dr-death's Avatar
Default 05 Tucson GLS 4x4 with 200300 miles
Hello Again Still looking to Fix these bugs!!
I have started to collect some parts
2 front ball joints
4 control arm bushings
Problems
***could this also be a wheel bearings***
p0700
p0741
p0430
Old 12-17-2010 | 09:29 AM
dr-death's Avatar
Any ideas?
Old 12-21-2010 | 10:42 AM
dr-death's Avatar
wow no help......no nothing ....must be i need a CHEVY!!
Old 12-21-2010 | 11:08 AM
1. get the wheels inspected for balance and check teh bearings and axles.
2. Inspect the control arm bushings
3. CEL:
- P0700 = Transmission Control System Malfunction (this code just lights the CEL)
- P0741 = Torque Converter Clutch Stuck Off (replace the solenoid)
- P0430 = Catalyst System Efficiency Below Threshold (Bank 2) (check the O2 sensors and if they are operating properly, inspect the cat)
Old 01-04-2011 | 09:48 AM
dr-death's Avatar
Thank You Nova
now that ive collected all new front end parts i am now looking for Torque Specs
any help ? locations for documented specs?
ball joint nut
ball joint to spindle
tie rod nut
kiton
11-17-2014 01:42 PM
Espen
09-17-2014 10:38 AM
dr-death
12-13-2012 10:54 PM
doug1234
11-14-2011 06:40 PM
04tibiinaz
11-13-2005 04:45 AM
