P2563 - Turbocharger (TC) boost control position sensor?
Old 12-09-2020 | 10:36 AM
AlexTucson's Avatar
Default P2563 - Turbocharger (TC) boost control position sensor?
I have a P2563 code in my 2015 Tucson (engine CRDi 16V, 2.0 136bhp).
The symptoms are low power, max 2,800 rpm and the yellow engine warning sign on the dashboard.
A possible cause could be the Turbocharger (TC) boost control position sensor but I am not an expert and cannot say WHERE it is so I could check voltages etc.
Could any good soul give me a hand, please?
Thanks!
Alex.
Car Scanner ELM OBD2
DTC report
Selected brand: Hyundai
============1==============
P2563
Raw code: 2563
ECU: Engine control unit
Status: Confirmed
OBDII: Turbocharger (TC) boost control position sensor - range/performance problem
============2==============
P2563(00)
Raw code: 256300
Status: Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
============3==============
P0524(00)
Raw code: 052400
ECU: Engine control unit[Archive (inactive)]
Status: Test failed since last DTC clear
OBDII: Engine oil pressure too low
============4==============
P0684(00)
Raw code: 068400
OBDII: Glow plug control module to ECM/PCM communication error - range/performance problem
============5==============
P2563(00)
Raw code: 256300
Old 12-09-2020 | 11:26 AM
From looking at the codes you posted, vehicle might have a power or ground problem.
Suggest you start by checking all the fuses, which could produce a problem with some sensors not working properly.
If you find nothing there , then would be a good idea to confirm ground connections are good
There are a few unrelated problems and questionable ground connections come into the picture..
Old 12-09-2020 | 12:07 PM
AlexTucson's Avatar
Many thanks! Will do it!
Old 02-15-2022 | 07:03 AM
Tattoosbyalexbach's Avatar
Default Hi
Thanks!
Alex.
DTC report
P2563
Raw code: 2563
Status: Confirmed
P2563(00)
Raw code: 256300
P0524(00)
Raw code: 052400
P0684(00)
Raw code: 068400
P2563(00)
Raw code: 256300
Did you manage to fix this. I've just got the same problem with mine. 2016 2.0 136hp diesel. I can't find any info on it. Thanks.
Old 02-15-2022 | 10:53 AM
Looking closely at the description of "range performance problem is appearing in more than one system. This tells us to look at what the two systems having a problem share or have in common. A good place to start might be with the power or grounds that these two systems appear to share.
Old 02-15-2022 | 11:19 AM
Thanks fir getting back to me. I'll get thst look into.
dadam
11-14-2010 10:41 AM
garybin5
10-08-2010 11:08 AM
kelvis97
04-18-2010 08:08 PM
Quick Reply: P2563 - Turbocharger (TC) boost control position sensor?
