Radio install for tucson 2008
1. Disconnect the negative(-) battery terminal.
2. Remove the shift lever ****(A).
3. Remove the console cover(B), disconnecting the shift lever connector(A).
4. Remove the upper plate from the transmission shift lever, then remove the 3 screws holding the center facia panel.
Remove the center facia panel(A) and disconnect the wire connectors.
5. Remove the audio unit after removing 4 screws.
6. Installation is the reverse of removal.
Boy_Narf
01-10-2009 11:08 PM
